Dissapointed about Spec 1 Clutch
Well guys i installed my spec stage 1 clutch about 200 miles ago and so far I am quite disapointed at how bad it chatters. It chatters really bad when reversing and in first gear and i dont see how i could have screwed up installing it. Is this normal for the Spec stage 1 or what could be doing this? I really dont feel like pulling the tranny again so hopefully it will go away if its just normal break-in procedure
RE: Dissapointed about Spec 1 Clutch
my spec one chatters in nuetral... i think the throwout bearing is already busted and ive only had the clutch for like 700 miles... kinda sad that it keeps breaking.
Did you resurface/replace the flywheel? If not, you're going to have an extended break-in time. Plus, it's not really the miles, it's the number of engagements.My Centerforce smoothed out within 150 miles with a resurfaced flywheel (took it cruising, so there was plenty of clutch work).
ok guys...thanx for the words of encouragement. I was going to ditch it and not bother with spec anymore lol. I resurfaced the flywheel and i did not replace the pilot bearing. I doubt it would be that because it appeared fine and the stock clutch did not chatter. 1st gear is starting to smooth out but reverse it killing me
