nitrous abuse
RE: nitrous abuse
100 shot or less with atune, a window switch, and a WOT switch and you can spray until you get tired of spraying. People will tell you nitrous is not good for your engine, and technically they are right. What they don't tell you is superchargers and turboswill decrease engine lifeas well. Heck, redlining a stock block with not power adder is not good for your engine either. The key with anything is to be smart about it. Don't let the guys that have never had nitrous talk you out of it. It is awesome!
RE: nitrous abuse
I've run nitrous on every mustang I've ever owned with no problems. I would get a window switch if I were you. On a 125 shot my tires broke loose one time and the engine hit the rev limiter before I could get my foot off the gas. It backfired through the intake so hard that it mushroomed my k&n and blew the carbon screen out of the maf. If you have a standard then get a window switch for sure. It'll cut the nitrous off at what rpm you want it to.
RE: nitrous abuse
Original: bransdaman78
well this isnt the time to tell you that n02 isnt the best thing you could have put on your motor if your worried abotu blowing it
if you do research and get the necessary safety equipment (bottle warmer, purge, window switch, etc etc...you should be fine). oh...and never jet in 5th gear. ever.
RE: nitrous abuse
ORIGINAL: kshwannabe
what happens if you do use it in 5 gear
