85 at 25
Old Jan 18, 2007 | 10:56 PM
SINISTER's Avatar
SINISTER
Default RE: 85 at 25
Sounds like you have stock gears to me as well. To use the gear calculator, make sure you plug in the correct tire size you have on you rear tires, select the right transmission, and if a manual make sure you have the gear selected as 5th gear.
Old Jan 18, 2007 | 11:00 PM
Dan04COBRA's Avatar
Dan04COBRA
Stock gears. Why would you think a CAI & K&N isn't normal? Everybody and their mom has them on their V6 or V8 Mustangs.
If your differential cover isn't stock, you should give the car a good inspection for body work and other suspension work as little things like that are tell-tale signs it's been through the ringer once or twice.
Old Jan 19, 2007 | 12:49 AM
beastzilla02's Avatar
beastzilla02
k so then how come it dies down at like 90 mph tho?? like when it hits 4th or something..i mean it pulls but nothing like 0-90.
Old Jan 19, 2007 | 01:25 AM
eventer289's Avatar
eventer289
ORIGINAL: allblack02GT
Because you have run out of gear. The 3.27's are dropping you out of your power range in the higher gears. Throw some 4.10's in there and it'll pull a little harder.
Old Jan 19, 2007 | 01:26 AM
ackuric's Avatar
ackuric
4th is a even ratio gear, not much power there unless its a 6 speed, then its gear differently and a bit higher.
Old Jan 19, 2007 | 01:28 AM
SpecterGT260's Avatar
SpecterGT260
are u an auto?
Old Jan 19, 2007 | 01:29 AM
handyandy's Avatar
handyandy
I think you were entering something wrong in that calculator, cuz it really does work. Make sure you have all of it correct, like your tranny and the gear specified and speed. With 4.10's, at 70-75 mph I'm at like 2500 rpm. I dunno if that means anything to you.
beastzilla02
ya its auto
Old Jan 19, 2007 | 02:45 AM
rbstang's Avatar
rbstang
you have stock gears. i dont know what tranny you have so i posted both.
3.27 gears, with 245/45/17 tires
4R70W(wide 2.84)
At 85 MPH in 4th gear, your motor is turning at 2,546.6 RPM
4R70W(std 2.40)
At 85 MPH in 4th gear, your motor is turning at 2,437.5 RPM
Old Jan 19, 2007 | 03:56 AM
beastzilla02
k so then i have stock gears then all i gotta say is wow..this car is way faster then my 97gt lol. i cant imagine how much quicker it will be with gears. time to buy some!
