My headlights won't light up, at all. If I pull the switch, my ambers and my taillights light up, but my fogs and my headlights won't ligh tup. On the dash, the high-beams/bright lights light is on, and I can't get it off. I try to pull/push the turn signal stalk, and that doesn't do ****.
Dude ok. First check and see if you have any ***** haha then what you need to check for is to see if the little wire in the fuse is still there. If its busted then its blown. Or get a meter and set it to ohms and if its an open circut then its blown but if it gives you some kind of number its still good. . . but im guessing you probably dont have a volt meter. . . .
