Will changing the transmission fluid make a differance.
Old Jan 22, 2007 | 01:44 PM
InferRedd's Avatar
InferRedd
Default Will changing the transmission fluid make a differance.
I know changing my transmission fluid will make a differance will alot of things, but my question is, should I change my fluid to see if this will help with my grinding gears and 2nd popping out, before actually rebuilding my tranny? Also what is a good fluid brand to put in?
-Thank you.
Old Jan 22, 2007 | 01:46 PM
wildazme's Avatar
wildazme
Default RE: Will changing the transmission fluid make a differance.
changing the fluid might make it worse, i wouldnt unless its really burnt or smells really bad. if the fluid hasnt been changed since you had the car , it will tend to build a varnish on the parts and if you add new fluid it will clean those deposits off which could make it slip and grind more.
Old Jan 22, 2007 | 02:26 PM
InferRedd's Avatar
InferRedd
Alright thanks.
Urambo Tauro
Sep 7, 2015 12:47 PM
inyadreems
Aug 21, 2015 09:10 AM
antipeterleague
Aug 18, 2015 01:50 PM
Greyshot
Aug 15, 2015 03:32 AM
