got some FRPP stuff to install :)
RE: got some FRPP stuff to install :)
ORIGINAL: dubarado
nice shift ****!!!! Did you run into any airbag issues??? I'm worried about it popping out into my face...that'd suck.
ORIGINAL: BBond007
Here it is installed....
Install was simple. I only ran into one minor issue removing the old wheel.
The puller I bought did not have the correct bolts.
The steering wheel internals are aluminum so I just tapped to the thread pattern of the bolts that came with the puller.
ORIGINAL: handyandy
I wanna see that steering wheel.
Not that it was going to deploy, I disconnected the battery about an 1/2 hour before I started....
Just last time I disconnected the battery (to replace the terminals) my airbag light was flashing a "5-2" code for several weeks before it (for lack of a better explination) fixed itself. This time the airbag system did not have an issue.
I do like the shift **** also. I got it from here http://www.thehotrodgirl.com/
I actually used heavy-duty epoxy to attach it to the tri-ax. Its never comming off... haha
But the cool thing about it is that it never heats up and its totally visible when you are looking for it and its great (over stock) if you have big hands.
ORIGINAL: fiad06
that steering wheel looks the same as mine, i have the stock one?
I think this is probably what you have just overstuffed...
check here http://www.mustangworld.com/ourpics/fcar/fr500wheel.htm for a sise-by-side comparison
09-10-2015 08:39 PM
