Tech question
RE: Tech question
I did you bastard! lol I even put some rust buster all around the crank pulley and that baby wont move!!!! There is only one bolt on the crank pulley know that. . . anything im leaving out?
RE: Tech question
LOL! Crank it until its supe tight, then tap it witha hammer. Make the pulley ring, it should come off. Some are kinda stubborn. Also, are you sure the puller is butted up against the crank only and not the pulley?
-P.
-P.
RE: Tech question
Yeah i tried to use a pry bad and thats no use. Get this i screwed it in so far its started taping into the threads[] and it seazed up and now its spinning the whole thing (crank shaft) [:@][:@][:@][:@]
RE: Tech question
ORIGINAL: P Zero
LOL! Crank it until its supe tight, then tap it with a hammer. Make the pulley ring, it should come off. Some are kinda stubborn. Also, are you sure the puller is butted up against the crank only and not the pulley?
-P.
-P.
