Steeda Shifter came today!! Help ASAP!!
Ok, I ordered some redline tranny fluid that should be here friday. I here it's better to fill the tranny through the shifter. BUT I really want to install this shifter NOW!! Will it work just as good to use the fill hole?? w/ a fluid pump?!?
I have ADD/ADHD really bad, and I don't think I can wait till friday night to install it!!!!!
RE: Steeda Shifter came today!! Help ASAP!!
I'm in the middle of installing the shifter! Need some help.. It says NOT to install the rubber boot that was attached to the factory shifter!? If I leave it out won't dirt & $hit get into the shifter/transmission?
Im assuming you mean the little rubber boot on the inside of the outside leather boot. You may need to cut it so it fits but you can reinstall it. I did and it all worked out just right.
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
