halfshafts
Old Jan 31, 2007 | 02:07 AM
therapist's Avatar
therapist
Default halfshafts
what needs to be done to run DR's or even slicks on my 2001 cobra. i've heard everything in my axle is good except for the halfshafts? and to upgrade to 03/04 cobra halfshafts? i dont kno what that means but what needs to be done so i can leave pretty hard?
Old Jan 31, 2007 | 02:23 AM
PWORLDSTANG's Avatar
PWORLDSTANG
Default RE: halfshafts
I'm assuming somone told you you have weak or bad half shafts then right?.. I'm not sure if the 01's and 03-04's have the same halfshaft, but the 03-04 halfshafts are pretty expensive. I think somewhere between $1000 and $1500.
Old Jan 31, 2007 | 03:24 PM
therapist's Avatar
therapist
ok, well i guess forget me askin about 03/04 halfshafts. but is there any other way to make my axle stronger? i saw a brace for the irs somewhere. i dont really know what needs to be done but hopefully there is an inexpensive way to make it a lil stronger.
Old Jan 31, 2007 | 03:28 PM
rbstang's Avatar
rbstang
i dont know what a half shaft is but if "I" were gonna run slicks which one day i probably will... i would go with
31 Spline Moser Axles
31 Spline Eaton Posi LSD Differential
T/A Girdle thingy
and um ya that should be good enough.
Old Jan 31, 2007 | 04:02 PM
PWORLDSTANG
ORIGINAL: therapist
Lol. Yea, those damn halfshafts are expensive! Even to replace the stock ones. And theaftermarket ones are even more money.But yes, there is a brace. And it's considered to be one of the best investments on IRS stangs. It is an IRS brace made by a company called BilletFlow. They make the best brace available for the IRS. And it's cheap! Only $150.00! The brace supports the differential cover, which has the tendency to flex and break. You can get it from http://www.lethalperformance.com/.I just checked for you. After you click 99-01 Cobra, It's under suspension/braces and brackets.
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
AMAlexLazarus
AmericanMuscle.com
Nov 14, 2014 07:14 AM
AMAlexLazarus
AmericanMuscle.com
Oct 3, 2014 03:16 PM
Aereon
SVT Forums
Jan 28, 2009 09:59 PM
torqjnky
Jun 30, 2008 10:10 PM
