brakes
RE: brakes
Sounds like low fluid to me. When you hit the brakes the fluid is pushed out of the resevior down into tubing and calipers, that empties your res. causing the wrning light to signal. A surge forward or backward of the vehicles motion can cause this as well. Use Dot 3 or better brake fluid and get that crap taken care of pronto. This is also a sign that your brake pads have worn down, causing the calipers to push in farther then normal to contact what pad you have left to the rotor, hence it will use more fluid then normal. Check on your pads and if you need new ones, change the pads before you add fluid, because with new pads the original fluid will rise back up.
RE: brakes
i was thinking about upgrading the front brakes ,what do you think of these rotors, http://www.americanmuscle.com/crdrandslrof.html
i wish i could find the cobra front brake kit for cheap somewhere
RE: brakes
im buying these rotors and pads.. $190.
http://cgi.ebay.com/ebaymotors/ws/eB...310&rd=1,1
