Starting Problems
Old Feb 1, 2007 | 02:22 PM
boeing747arowair's Avatar
boeing747arowair
Default Starting Problems
hey guys, i have an 01 gt and im having problems when i go to start it... it turnsover but it wont start until i let it crank for a while and let go of the key. any idea on whether its a sensor or something?
Old Feb 1, 2007 | 03:41 PM
JJ03MustangGT's Avatar
JJ03MustangGT
Default RE: Starting Problems
check your spark plugs....fuel filter. how many miles are on the car
Old Feb 1, 2007 | 04:00 PM
boeing747arowair
fuel filter is new, plugs shouldnt that be bad.. ther are about 70k miles on it! thanks for the help
Old Feb 1, 2007 | 04:03 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
does it crank and crank and crank and not start up, but eventually, it starts every time? kinda common, nobody seems to know the cause due to the intermittent nature of the problem.
Old Feb 1, 2007 | 04:08 PM
boeing747arowair
yea it starts everytime i jus have to crank it for a while and then when i let go of the key, it starts
Old Feb 1, 2007 | 05:09 PM
Roushy's Avatar
Roushy
Try this.....
When you turn the key and it starts to crank.... tap the gas a little and open up that TB. I found out I was running pig rich and had trouble turning over after the turn. All I have to do now is tap the gas when turning it over and it turns over after the 2nd crank.
Old Feb 1, 2007 | 05:41 PM
boeing747arowair
thanks alot ill try it out!
Old Feb 1, 2007 | 08:28 PM
ousooner28's Avatar
ousooner28
mines has the same problem but its not all the time
Since they are electric fuel pump turn the key to acc and wait a couple of seconds then start it
ive notice it does it less when you do this
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
