Comp Cams XE274h
RE: Comp Cams XE274h
So there is no way I can run these cams without fly cutting the pistons? What are the biggest comp cams i can run with PI heads?
and also the best sounding lopey cam? how do you go about fly cutting the pistons any detailed info.
The lopier the sound the less streetable it will be! Those are for high revving applications only. They will have big torque loos down low and you need 3000rpms before they begin to create the power. I would go with comp 102600 xe-270ah (stage 1)1800rpms-5800rpms or the comp cams 102700 Xe-278ah (stage 2) 2200-6200rpms Both of these with no probs, but the stage 1 can use your stock pi springs while the stage 2's you should really replace them
OHH, BY THE WAY the xe-274's are for non pi heads with only a .500 lift! You donot want them.. You could run them with no problems, but you would lose power from what you already have! It would be basically same as non-pi heads with a cam install! LOL
ORIGINAL: oxfordgt
Yes even with degreeing the cams you will on a 96. 99 and up not so much but the flattops in the 96 are what is going to cause it.
Original poster:
like said above, why are you going with cams for NPI heads?
If you want a really nice set of cams that will give you power go with the Crower st 2 NA.
ORIGINAL: tofasgt
so i can run the xe274h cams with no prob. right? and i ordered these cams before i decided to do the PI swap but if there gonna hurt instead of help I think i will swap!
thanx guys!
thanx guys!
junior04
09-28-2015 10:53 AM
