Suspension help?
I have tires and am getting gears but I want to get something to stabilize the rear end.... Do sway bars work well and if so what kind should I look for....I also have plans for springs/shocks/stuts.
I only have a small budget.......less than $500.......so I was thinking more along the lines of sway bars but I will look into those....will they help more than sway bars?
ORIGINAL: qbuswell
A nice and easy low-budget sway bar up-grade.
Subframe connectors they solidfy the body, make it feel a lot better.. you can pick em up cheap...
You might be able to do SFC and Lower Control arms for your 500$ and it will help the car.. all around for cornering and straight lines.
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
