anybody?
RE: anybody?
i had the light come on during a burnout one time and i just backed it out and parked till we found out what was wrong with it. it ended up being too lean.... glad i didn't run it...
what exactly is the evap code??
RE: anybody?
what is the code?? i will see if i can help out and do some research on it.
i know there is a code in the expeditions that is for that. has something to do with the gas cap not being on completly. its loosing pressure so it throws the check engine light. fiddle around with your gas cap while the car is off and then see if the light goes away.
RE: anybody?
I dont remember the code. But I'll get my friend to check it asap.
Yeah, about losing pressure in the tank. I know when I drive other cars to E. And take off the cap they will hiss. Mine dose'nt hiss. Nothing, no pressure or anything.
THANKS
THANKS
RE: anybody?
It wont hiss. lol. I know what youre talking about. Dont run youre pony to "e" either. Dont over fill it either or you'll get the same EVAP code. Run it with the light on. EVAP is ****, wont hurt you. I ran mine rich, then got it tuned. I ran .2 second better. But i also got a chip. Who knows. I took care of that though. Maybe you have a bad gas cap. They are common on fords. Go figure
RE: anybody?
YEA, I took it out anyway. Ran a freaking 15.3 at 92 mph. [:'(] My 60' was like 2.5.
Ne ways tell me if this sounds wierd. I raced my friend with a gtp and he won running a 14.5. BUT, on the way home I smoked him 3 times from 50 to 120????? Anybody know whats up with that! I started walking on him from the beging and never stoped untill I let off.?????
RE: anybody?
I believe you posted in another thread that I didnt know **** and was kinda hesitant about helping here but I figured to go ahead. These are the trouble codes for the evap system.
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
Now if you can pin point the code I might be able to help a little more. That is if im not to dumb that is! [>:]
