bugs in guages(literally) help.
is there an easy way to get the bugs out of my guages? u know the dead ones. without taking everything apart maybe blow em out some how. If i have to take it apart how hard is it.
ORIGINAL: jdavis
ORIGINAL: AllGo5.0
+1, lol
ORIGINAL: wgdt21
wtf? how did bugs get in your gauges?
ORIGINAL: ponysnake99
its not too hard, just 2 bolts up top (8mm i believe), then the hardest part is removing the headlight **** (its a little hard to explain...here)...just take your time with it, a small flat head works best. then its just 4 bolts holding the cluster in if you need to go that far...have fun...and try to figure out where the bugs are coming in from
ORIGINAL: jdavis
Just bend a nail at a 90* angle using a pair of plyers and then put it into the little slot and lift up and pull the **** off.
