NEED HELP white face gauge wireing
Old 02-07-2007, 11:31 AM
mvr
mvr's Avatar
Default NEED HELP white face gauge wireing
so i bought these white face glow gauge overlays off ebay.
after strugling with the headlight **** i got it off and had the new overlays in a short time after. i have the cluster back together, no problems there. now when we started to do the wireing for the glow part thats where we are stuck at. i used the americanmuscle.com walk through as a guide to installing these. it said to use the grey wire and you tap into it for power, well we did that, and we grounded it exactly like the walk through said. with self tapping screw in the back metal bar behind the cluster. so if any of you have installed these types of gauge overlays before where there is wiring involved could you please tell me what im doing wrong. i really hope the switch is not defective.
here are some pictures of where we are at.
heres the walk through i was following
http://www.americanmuscle.com/mustan...es-how-to.html
mvr is offline
Old 02-07-2007, 11:35 AM
wes ley n the G T
wes ley n the G T's Avatar
Default RE: NEED HELP white face gauge wireing
Get a screwdriver and shave under the ground screw to make sure its gettin good contact with the chassis. Also on some cars, the wire isnt grey, its brown. Just look for the biggest brown or grey thick wire, and splice into that. If you splice the right wirem when you turn the headlights on the gauges will glow.
wes ley n the G T is offline
Old 02-07-2007, 11:39 AM
mvr
mvr's Avatar
LOL its that huge brown wire in the middle!!!!!
HAHAH i suggested that that may be the wire... my dads like were doing this one cuz its the only grey one. [:@]
shiiiiat
mvr is offline
Old 02-07-2007, 11:49 AM
mvr
mvr's Avatar
i just went and took another picture, it shows the wires better. there is a huge brown one in the middle, we have been working off a small grey on on the side.
can anyone confirm which cable i should be working off?
mvr is offline
Old 02-07-2007, 01:24 PM
mvr
mvr's Avatar
TTT bump!
anyone???
mvr is offline
Old 02-07-2007, 01:33 PM
BraMas
BraMas's Avatar
Here is what I did when I put mine in. I took a test light (onewith a point on it) and probed the wires until I found the wire that turned on when you pulled the headlight switch and it just happen to be the one that controls the dash dimmer and I tapped into that one. You can get to the wires from the back of the plug so you don't have to poke into the coating.
BraMas is offline
Old 02-07-2007, 02:20 PM
mvr
mvr's Avatar
were going to get a voltage meter or continuity(sp) tester and test all the wires when i get home from school.
i still need to find out if the wire we tapped into is the right one [sm=bangbang.gif]
mvr is offline
Old 02-07-2007, 02:25 PM
03mustgt
03mustgt's Avatar
When I wired mine i didnt have to tap into any wires, There is an empty connection on the back of your headlight switch that will give the dimmer/headlight/parking light power. Just use your probe and find it, slip a connection on it, and your done. No splicing or anything.
03mustgt is offline
Old 02-07-2007, 02:32 PM
mvr
mvr's Avatar
ORIGINAL: 03mustgt
orly... ok il look for that firstbefore i start cutting more wires [sm=thanx.gif]
mvr is offline
Old 02-07-2007, 02:52 PM
wes ley n the G T
Its the thick brown wire. This wire is thick because it controls the headlight and dashlight power. Just tap into that wire with a connector, and when you pull the headlight **** it'll turn on the lights and your EL gauges.
Quick Reply: NEED HELP white face gauge wireing
