What to do to make 350-400 hp on N/A 2v npi
#22
RE: What to do to make 350-400 hp on N/A 2v npi
ORIGINAL: jgorm
Do you have to worry about smog? Most of these options wont pass smog in most states. Slap a blower on it and be done for <5K and still pass smog. I have a freind with a NPI motor and vortech at 12 lbs and sees 365hp/385tq.
Sorry did not see the other one post
#23
Trade your car into a dealership for an '03-'04 Cobra and use the $5,500 for a down payment. Bet you'll get a hell of an interest rate with that kind of up front cash. Going fast problem is then solved. OR you can do itthe hard/frustrating/questionably reliable way like the rest of us GT owners and spend big money on a set-up that wasn't meant to go faster then 13s
#24
If you are determined to stay NA you can hit 350rwhp but it won't be cheap. You can also get there with NPI heads and again they won't be cheap. A set of P&P'd NPI heads done by Jim at Renegade Racing will flow as much or more then any P&P'd PI head but he is not cheap. Add a SVO/FRPP Intake w port work done to it and some nasty cams along with all the bolt ons and you could be in the 330-350rwhp range but you will exceed your $5000 budget.
It is much easier to slap on a blower and it will actually be better to drive a supercharged 4.6 as a DD then a fully worked NA 2V that in the 330rwhp+ range.
#25
ORIGINAL: droptoppony
#28
ORIGINAL: oxfordgt
10 There sill be alot of fabrercation that will need to be done like k member and firewall. You will never reach those numbers with NPI heads. I have spent almost $8000 on my motor trying to build a NA 400rwhp mustang and so far only a 386. Few more things to add and I should be over 400 but it costs alot.
#29
ORIGINAL: 04gtmatt
big bore nasty custom cams svo heads intake all bolts and 12.1 compression on a 2v made 430rwhp. go to modular power house and do a search
#30
ORIGINAL: hotrod7687
If you're set on making power and staying n/a, you might look into buying a nice fox body and upgrading the engine in it. You should be able to get a nice fox body with a 5.0 for somewhere around 2-3k. The 5.0 responds way better to mods and is much cheaper to build than a 4.6. You couldstroke the 5.0 to a347 that would put out some sick hp numbers.
If you're looking for the cheapest route n/a, that would probablybe it.
you're talkin some serious coin here, but ya i've heard about that car. fastest n/a 2v isn't it?
