Need help on Rev limitors?????
you do understand by lowering your rev limiter you are putting your car in a higher chance of issues...when you hit the limiter the fuel cuts off...and you are then going lean and could have detonation. You should raise the limiter not lower it.
ORIGINAL: droptoppony
ORIGINAL: 97targa
The whole point of a Rev limiter is to LIMIT the rpms incase of a miss shift or an accident. I will never run my car up to 6000rpms before I shift! You don't gain any more power past a certain rpms deepending on the application. So, if I set my limitor at 5800 per say. I'll probably never hit that unless I miss a shift. If I raise it to say 7krpms and I miss a shift power shifting then I have to watch my r's soar to 7grand??? Not this guy. Thnanks for the concern though!
I was merely stating examples. I won't know what my peak power is until the dyno. But yes I usually find the peak and shift about 2-300rpms past that depending on the situation! I also plan on setting the rev limiter about 300rpms past the point of shifting. So that means if my car peaks out at 5600 my rev limiter will be set at 6-6150rpms
ORIGINAL: ant02gt
my math says 5600+300ish = 5900ish...i could be wrong though.
and i dont see the need to lower the rev limiter...
hmm what happend to the days when revs were limited by the driver?
I am able to limit my revs on every shift without a tuner, its called a clutch pedal a gas pedal and movement of the shifter
You will not damage the engine on your car (97targa) by reving it to the stock limiter of (I think) 6200 RPM. I have bounced mine off the limiter more times than I can count with 420+ WHP on tap and a blown setup (which makes everything worse).
All of the settings you are talking about can be changed with a handheld tuner like a SCT. There is no need to swap out ingnition parts for this setup, just buy a couple hundred dollar tuner and set the point where you want it.
dont need to lower it, it was set at 6k from the factory for a reason, you shift at 5800 rpms, and the 6k limit is to let you rise 200rpm between shifts to get a tad bit mroe of a boost when you put it into gear. seriously, you will never get it abot 6k rpm, cuz that's what it's limited to, 200rpm wont do ****.
and if your reving while shifting, it probably means your powershifting, so you should be looking for new rearend/tranny before anything else.
ORIGINAL: 2000GT4.6
The fuel cutoff will not cause a lean condition, it kills ALL the fuel, so it simply has no detonation whatsoever. If the fuel cutoff caused detonation to occur I would have a forged shortblock right now
