C/A install was a bich
The easyest way to get everything to line up correctly when putting them back togather is to use a come-along. The big hook thing with a chain attached, kinda like a big rachet strap. It makes pulling the axle easier on you and your body since it does all the work. I learned that the second time from my father. I love the steeda LCA's that I put on my car, now if i could only do the uppers.
ORIGINAL: lizzyfan
I have no clue why you all did not do booth at the same time. Upper/Lower C/A
apparently you havnt done them before. Its alot of work, if you drive you car everyday it would be outta commision for a lil while.
ORIGINAL: 99mustang0
ORIGINAL: lizzyfan
ORIGINAL: lizzyfan
Ummm, hello! I did em' back in November in about 3 hours time on a friends lift. Both upper and lower, PITA but not something you'd do in stages and surely not put you out of commision
ORIGINAL: lizzyfan
Of course its easier to do ANYTHING on a lift thats obvious. The guy probably had to work with jack and jackstands like most people, which is why it was hard and took longer than expected. Cut him some slack lol
ORIGINAL: wes ley n the G T
KEYWORD: "lift"
ORIGINAL: lizzyfan
ORIGINAL: lizzyfan
ORIGINAL: lizzyfan
