Pulling the heads... fingers crossed
Old 02-13-2007, 02:43 PM
Nitti00GT
Nitti00GT's Avatar
Default Pulling the heads... fingers crossed
I am going to attempt to pull my heads. My valve seals have went on two of the cylinders on my drivers side, on top of that I have a cracked intake manifold so that is getting replaced to (so much **** is going on this thing!). I am taking the headsdown to a performance/machine shop where they said they will recondition both heads for $110. They said they could port them for $75 an hour, depending on what port job I am going with it should take 1-3 hours per head.
Is the port job worth it? Any suggestions on pulling the heads?
Nitti00GT is offline
Old 02-13-2007, 02:51 PM
bransdaman78
I ♥ Acer
bransdaman78's Avatar
Default RE: Pulling the heads... fingers crossed
yea its worth it, port match and polish
bransdaman78 is offline
Old 02-13-2007, 02:56 PM
racer02GTstang
racer02GTstang's Avatar
it should take about 12 hours to get the heads off for the first time... you have to remove the radiator to better access (i stood inside the engine bay taking the headers off the heads... if you have stock manifolds it will be alot easier than having LT's... i took my heads off with the engine still in the car..
racer02GTstang is offline
Old 02-13-2007, 02:59 PM
Nitti00GT
Nitti00GT's Avatar
Yeah I have stock exhaust manifolds. Getting everthing back on and having the car start is what I am worried about. I concider myself mechanically inclined and I read up on head removal and installation so wish me luck lol.
Old 02-13-2007, 03:08 PM
racer02GTstang
ORIGINAL: 00TropicGreenStang
well... for the timing chain... what i did was took a bunch of zip ties.. and i zip tied the gears to the chain.. its kinda redneck but if it saves me from having to retime the car, its well worth it.
Old 02-13-2007, 03:13 PM
Nitti00GT
Nitti00GT's Avatar
ORIGINAL: racer02GTstang
Haha sounds like it would work though. I was just gonna put a dot on the chain and a dot on the sproket next to each other and match them up when I put it back on. Also don't you have to turn the motor so thata notch on the crack shaft is pointing up. They said to do this so that none of the pistons are at TDC and that the valves won't get crushed.
Old 02-13-2007, 03:16 PM
racer02GTstang
ive never heard of this... i know as soon as you put the cams on, the valves will open up again.. but i dont think the car would have trouble with it, as long as the valve is forced into it.... im sure if you slowly turn the motor by hand, your not gonna hurt a valve.
Old 02-13-2007, 03:22 PM
Nitti00GT
Nitti00GT's Avatar
oh ok, I'll let you know how it goes. I might wait til next week cause of all the snow we are getting this week.
Old 02-13-2007, 03:31 PM
racer02GTstang
oh, are you having to do this job outside?
Old 02-13-2007, 04:06 PM
Nitti00GT
Nitti00GT's Avatar
Unfortunatly yes. My garage is way topacked with crapand its pretty small, kinda wierd since it was built in the 50's and cars back then were tanks.
Quick Reply: Pulling the heads... fingers crossed
