im so damn happy!!!! wooooot woooot
RE: im so damn happy!!!! wooooot woooot
so you will be able to make 440rwhp and 420 torque from a forged shortblock from MMR and VT stage 3 blower cams & ported heads i assume you will need a blower too, which one r u getting
ORIGINAL: amoosenamedhank
Wow, I just googled it. That's good stuff and a great deal for $2k
ORIGINAL: racer02GTstang
its a cryotreated tko500 that is good up to 750hp or 10.00 and slower in the 1/4
Oops I didn't type fast enough. What is a PRO 750 tko 500?
ORIGINAL: mustang02racing
i would be asshamed to only make those numbers with all that into the car...
i made those numbers with full bolt ons and the blower... not including the shortblock, heads, or cams..
at the 10psi im hoping to make somewhere in the low 500 range..
ORIGINAL: Maverick04GT
Man, with a forged shortblock and a stage 3 blower cam, I'd be pushing the boost as far as I could!
i got stage one comp cams and im not too happy, but the stage two and three cams need valve clearance so that means you got dished piston and lowered ur compression rite, what cc pistons u get
i have 17cc dished pistons with notches cut in them for valve clearance... my stage 3 cams did clear on the stock pistons... the new pistons will lower my compression to 9.0:1
really they do clear the stock pistons i was told they require notched pistons and the stock one would smack the valves that sucks i would have got them instead on stage one. are the stage three XE272AH or something like that. from comp cam
downshifting to much.. i was told those trannies dont like to downshift and from downshifting frequently, i messed up the syncro...
ORIGINAL: 2000GT4.6
How did you hurt that?
it is a tko... lol its the PRO750 TKO500
ORIGINAL: 2000GT4.6
rebuild it, sell it, and buy a TKO FTW!
