New Trick Flow Intake Manifold
Has anyone got or heard things about the new Trick Flow intake manifold? I opened up a Summit I just got and its has it in their for 799.95. Would you see any gains from this without having aftermarket heads?
RE: New Trick Flow Intake Manifold
There is no such thing as aftermarket heads. They're only ported stock heads. The gains would be more noticible with ported heads, but there is probobly some gain with non-ported heads.
Here is what I found after a google search:
Trick Flow 4.6L 2V Track Heat Intake Manifold
General Specifications
Made in the U.S.A
Material—A319 Aluminum alloy.
Designed for 1999-2004 4.6L Mustang GT ( modifications required for 1996-’98 models ).
Fits 1999-2004 Power Improvement head ports.
75mm Throttle Body Inlet.
Symmetrical high velocity intake port design.
3-PC design.
Accepts, but does not require aftermarket high-flow fuel rails.
2001 Special Edition Mustang performance when used on unmodified Mustang GT without costly additional components.
Increased performance potential over similar more expensive manifolds.
RPM Range: 1500-6500 when used with un-ported cylinder heads.
RPM Range: 1500-7200 when used with aftermarket or ported cylinder heads.
Same overall height as stock plastic lower intake manifold/ upper plenum assembly to minimize hood clearance issues.
Complete kit with detailed installation instructions for 1999-2004 4.6L Mustang GT.
Part Number: TFS-51800002 ( Silver metalic powder coated finish)
Part Number: TFS-518B0002 ( Natural finish )
Part Number: TFS-51811002 ( Black powder coated finish )
Estimated M.S.R.P ( < or = ) $ 799.00 ( Available Early Spring 2007 )
Additional Track Heat 2V Intake Manifold Components from Trick Flow
High-Flow extruded aluminum fuel rails and mounting brackets: TFS-5188000R
Twin 57mm throttle body Track Heat manifold. (Available Late Spring 2007 )
5.4L Track Heat 1999-2004 Mustang GT manifold. ( Available Summer 2007 )
Artie Kakiou Technical Advisor
email: akakiou@trickflow.com
Tele: 330-630-1555 Ext: 6324
[IMG]local://upfiles/29472/02AB583FDED54F2AB55F3242B9A079CC.jpg[/IMG]
Made in the U.S.A
3-PC design.
