kenne bell with 15lbs
i know im gettin new pistons with a 9:0:1 compression, 42 lb fuel injectors, aeromotive upgraded fuel presseure regulator, fuel rails and fuel pump, my kennebell intake and bust a spark all the gauges and definately a new clutch. what else is there i need it all just to hold 15lbs of boost? and this is goin on 1 97 cobra with 35k miles on it!!! appreciate the help.
RE: kenne bell with 15lbs
Tranny will go about 300 feet before it shreds into pieces.
funny yall say that. ls2 klr on modulardepot.com has a 302 stroker with a 200 shot and his t45 lasted 1 year of abuse. I just called him and were actually doing our fist twin turbo set up on his car. but with the t45 its a crap shoot. it will last a while or no time at all
Your list is currently at a new shortblock, sticky tires, new tranny.. don't forget that built rear end. Then do some suspension work. Then when that's all done, have fun with your brand new car lol.
you will probably need some 60 lb injectors... 42's shouldnt be able to support that much boost.. maybe 12-13 psi.. but no way 15psi... they will max out... also, pistons wont be good enough.. you already have a forged crank... but you will need rods and pistons... the rods are weaker than those pistons in your car, the rods are the weakest link...
and i hope this KB is intercooled cuz you need it...
