DOHC HEADS ON A SOHC ?
RE: DOHC HEADS ON A SOHC ?
ORIGINAL: 98redgt4.6
what kind of parts and how could u tell because my aunt says it had a top end rebuild and that she had dohc put on instaed of sohc
this makes me wonder, is a sohc block different than a dohc block, becuse if not actually the only thing that would need done would probly be a cam gear, dohc timing chains, intake and a tune. forget ecu it can be programmed accordingly
anyone have a pic of the surface of a dohc and sohc head, and same pics of block, maybe even measurments?
Q: Will 4V Cobra heads bolt to my 2V GT motor? A: Physically yes, but they will require that you use the '03 Cobra adjusters and related hardware. Don't forget the intake and related components also along. It's not an easy swap, but it can be done.
