My car makes noice when i turn the wheels...?
Old 02-16-2007, 03:31 AM
88 GT n loven it....
88 GT n loven it....'s Avatar
Default My car makes noice when i turn the wheels...?
When im driving my car or even when i am completely stop'd and i move the front wheels from one side to another it makes a squeek or something similar to a whistle, do you guys have any idea what can this noise be ? i check thesteering pump oil and it was fine any other suggestion on what could this bethe car has 90k miles....
88 GT n loven it.... is offline
Old 02-16-2007, 03:42 AM
Quicktime_GT
Quicktime_GT's Avatar
Default RE: My car makes noice when i turn the wheels...?
sound like it coming from the rack?
Quicktime_GT is offline
Old 02-16-2007, 03:49 AM
yes i think it is coming from the rack because where the lines connect it has oil, but i dont know if this mean'sthat it's a bad rack alredy or what ?
Old 02-16-2007, 03:50 AM
Quicktime_GT
ORIGINAL: 88 GT n loven it....
hmmmm..... Lucas makes a rack and pinion treatment I think.... may wanna look into it
Its usually a power steering pump problem though...
Is it worse when your not rolling?
Old 02-16-2007, 12:32 PM
M1ke
M1ke's Avatar
yeah lucas makes power steering stop leak. id try that first
M1ke is offline
Old 02-16-2007, 01:21 PM
ShadowDrake
ShadowDrake's Avatar
It happens to mine, too. There is a TSB on it. It is not leaking power steering fluid, as I've never had to add fluid to it. It's not the power steering pump making the noise as it really makes a different kind of noise. The TSB is for the rack bushings... buy some nice aluminum ones and it should correct the problem.
ShadowDrake is offline
Old 02-16-2007, 01:26 PM
Miliock
Miliock's Avatar
ORIGINAL: ShadowDrake
he has an 88
Miliock is offline
Old 02-17-2007, 06:34 AM
ORIGINAL: Miliock
he has an 88
HAD THE 88 SOLD IT AND NOW BOUGHT A 98 GT....lol
and yes it does make a louder noise when its not rolling( Quicktime_GT ), when it's rolling u can barely hear the squeek ...lol and i dont think its leaking because it doesnt need any power steering fluid ...
Old 02-19-2007, 03:43 AM
bump^ i was wondering if maybe a lube would make the noise go away...
Old 02-19-2007, 07:10 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
The TSB that was mentioned says it's for the 2002-2004 Mustang, however I believe the steering rack mounts are the same or similar on your '98. Have a helper rock the steering wheel while you observe the rack, if it's moving back and forth in synch with the noise then the problem is loose or worn rubber bushings.[/align][/align]For the '02-'04 TSB Ford supplies a shorter tube bracket (as it's a design issue), however in your case the bushings may just need replacement (my DIY fix shown here might fix it up if the bushings are not spongy or deteriorated).[/align]
cliffyk is offline
Quick Reply: My car makes noice when i turn the wheels...?
