Best HP bang for the buck?
RE: Best HP bang for the buck?
ORIGINAL: hammerdown99
I believe they do
ORIGINAL: tehzack
Gears should be everyone's first mod. OT here but... Don't verts come with SFC's?
I believe they do
I believe they do
ORIGINAL: tehzack
I believe they do
yes they do, also them come with a k member brace... but jiust because the vert has these, does not mean the aftermarket is better... those subframeframe connectors are the worst ive seen yet.. when i put the new ones on the car handled so much better and was much much stiffer... the stock ones are bolt on and flimsyand when you take them off you barely notice the difference in worse handling...
if all you are aiming for is 14.2's i would go with gears, upper and lower control arms, sfc's and how bout some drag radials. that should get you right where you wanna be. also jegs sells a supspension drag kit for our mustangs. you gotta be able to plant the power before you add more of it.
