Problems with SpeedCal
RE: Problems with SpeedCal
You can jack your rear up and turn the tire 2 complete turns while watching your driveshaft and counting how many times the driveshaft turns. 3 3/4 turns on the driveshaft should be 3.73, 3 1/2 turns = 3.55, a bit over 4 turns = 4.10.....well you get the picture. If Im wrong, correct me please...
ORIGINAL: Pitt
ok, so i finaly got around to testing it out and I do indeed have 3.73 gears.So what the heck is the problem? is it possiblethat the electronic sending unit has failed? Has that happened to anyone?
You need to do one or the other not both! i just read up and talked to a rep about it. Just stick the 23 tooth white gear in there and call it a day. Or put one in for another gear ratio and enter the code! Doesn't matter what gear you put in as long as you adjust the code for it.
ORIGINAL: 97targa
Why is the white 23 tooth bad? Why does it get all torn up vs. other gears? Isn't the stock a plastic peice as well? I'm not sure why you are having trouble, but ya think you can help me with mine???...lol
ORIGINAL: 97targa
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
