265 too wide in front?
I'm looking at buying some Kumho MX tires for the stang. I just ordered 18x9 and 18x10 rims and i'm going with 295-35-18 in back and the smallest size they make them in with a 35 profile is 265. I wanna keep the same tire and profile all around, so do you think 265 is too wide for the front tires?
RE: 265 too wide in front?
a 265/35 will be much shorter in outside diameter than a 285/35. 35 is not a constant measurement. The 35 means 35% of the width of the tire while the 285 is the width.
You may get some of the 18 inch guys to tell you a good front/rear tire setup.
I'm running 315/35/17s and 245/45/17s and they are the same diameter..
ORIGINAL: Quicktime_GT
i'm thinking of running a set up like that.
i'm running 315s in the back for sure,
but i'm still debating on how big to go in the front.
ORIGINAL: matts0809
do you have any pics of your tiresi could see???
ORIGINAL: MustangMan528
how many of you guys are running taller profiles in front as opposed to the profile on the tires in back??? Ex: 295-35-18 rear and 245-40-18 front.
i run 275 all around, no problems except when i do a U turn sometimes it makes a weird rubbing sound but i can usually do them without wheel all the way around =p (just rev and drop clutch 70%)
You'll be fine with a 265 in the front. I'm running that with my 18's on the front, and I have no clearance issues, and it looks good. I have a 285 rear, on the 18x10 rim, and it isn't wide enough, so the 295 will fit better. As for the profile, I went with a 35 all the way around, and I don't notice a difference.
