Idle rpm
Old Feb 19, 2007 | 06:59 PM
yoteehunter's Avatar
yoteehunter
Default Idle rpm
Is there any way to manuely adjust the idle speed. My car is idling at 950rpm and I would like it to be down around 750.
Old Feb 19, 2007 | 07:15 PM
devsredgt's Avatar
devsredgt
Default RE: Idle rpm
ya you have to...while the car is running...undo the idle air bypass plug. the car will either putt out or it may rev to a high rpm. while this is disconnected set the idle with the gold colored screw on the front of the tb. tur turn the screw clockwise to lower...oposite to raise. when your done reconnect the idle air bypass plug and your set.
Old Feb 19, 2007 | 07:45 PM
8banger's Avatar
8banger
Might be a good Idea to Clean the throttle body(with approved cleaner) and the IAC motor...first...
Old Feb 19, 2007 | 07:58 PM
yoteehunter
is it a screw in the linkage itself?
Old Feb 19, 2007 | 08:04 PM
devsredgt's Avatar
devsredgt
its on the front right...your left...of the tb right next to where the hose connects.
4cylinderplus2
Oct 9, 2020 07:45 PM
CS2007
Jun 25, 2019 09:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
