springs and wheels questions
I'm thinking about getting some 03/04 chrome Cobra rims. Is there anything wrong with keeping my 245/45/17's on the new 17x9 rims? Will they fit? Also, recommendations on where to buy these rims from would help. How about americanmuscle.com?
And if I ever got some lowering springs like eibach pro kit or H&R springs would I get any problems? Any spring recommendations? I'm sick of the "4x4 look" lol. I want a medium drop, nothing too low and nothing too high. But a good looking stance. I need information.
Thank you all.
Thank you all.
RE: springs and wheels questions
eh, the tires will look a little bit streched onto the rims.. Perfect size would be 275/40.. and you won't have any problems with a drop.. But I personally would get the 17x9/10.5 combo just because having wide tires in the rear give it a great look..
I've got FRPP "C" springs on mine and they dropped it to the max of my stock c/c plates.. The guy actually drilled out the pop rivets to get the most out of them... I also ditched the front top spring isolators..
I think I want about a 1.5 inch drop, like what the Eibach pro kit drops. Because I don't want to have to mess around with c/c plates and other components. I have read here I don't need new shocks and springs with a 1.5 inch drop.
ORIGINAL: devsredgt
if you get springs you need to get new shocks and struts as well. if you go lower than2 you might need to invest in some cc plates.
ORIGINAL: sitnlopro99gt
You dont HAVE to get new shocks and struts though it will help the ride quality a lot....... if you go lower than 1.5" you will need c/c plates to be able to prop. adjust within specs......I would not put the tires on the those nice cobra rims, I would save a little bit more to get some nice ones that will look really good on your stang just my .02. Dan
ORIGINAL: devsredgt
Sorry..I mean the rims look great I just wouldnt scarifice them for the tires off your stock rims..save up for some appropriate tires for that size.....it will look stretched like mentioned above. I would do at least a 275 outback and maybe a 255/265 front....it will be worth the wait/decision. Dan
most guys would recommend new shocks\struts. you dont have to get any thing you dont want to get. its just that it would be a wise decision. you need new s\s to allow for the shorter springs. just my .02.
