temp range
Old Feb 20, 2007 | 06:13 PM
stangdriver2007's Avatar
stangdriver2007
Default temp range
does anybody elses 4.6 go to about the r in normal on the temp guage when sitting and when driving to the N in normal and if not what might be wrong
Old Feb 21, 2007 | 12:33 AM
stangdriver2007
Default RE: temp range
how about this my car has a slight smell of antifreeze could it be that when it is idling it gets warmer cuz the pressure is not as high
Old Feb 22, 2007 | 12:24 AM
stangdriver2007
ok i found my raidiator has a crack in the plastic so im putting a new one in tomorrow i heard a few fords will idle a little warmer then drop back down but also after i fix the radiator it should level out am i right or not
Old Feb 22, 2007 | 12:35 AM
ponysnake99's Avatar
ponysnake99
if it idles a little warmer than drops then your thermostat is opening up...its not too abnormal to notice a slight flux in the temp guage
Old Feb 22, 2007 | 08:03 PM
stangdriver2007
another question will the coolant level light come on if its too full too or only to low cuz it is full and it comes on
Old Feb 22, 2007 | 08:22 PM
ponysnake99
there's a mark on the side for what the system should consider full, if not check the bobber in the coolant resevior, it is what triggers the check coolant light, make sure its not being hung up either
Old Feb 23, 2007 | 12:24 AM
stangdriver2007
the car will idle up the the M in normal and when it runs it will run at N is that much difference normal i will check the bobber
Old Feb 23, 2007 | 06:04 PM
stangdriver2007
please help me out
Old Feb 25, 2007 | 06:05 PM
stangdriver2007
somebody should know like everyone here is smart about this stuff
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
