Shift Kit
Old Feb 22, 2007 | 01:45 PM
Diesle's Avatar
Diesle
Default Shift Kit
Would this be a good shiftkit "TransGo Performance Shift Kits" for an 2000 automatic GT or what would you recommend ?
Old Feb 22, 2007 | 01:47 PM
yellowgtstang18's Avatar
yellowgtstang18
Default RE: Shift Kit
i heard trans go makes the best shift kit
Old Feb 22, 2007 | 01:52 PM
Chopper's Avatar
Chopper
I had good luck raising shift points and firmness using a chip in a Lincoln MK VIII.A handheld tuner would probably be better though.You can take this all with a grain of salt because I really have no first hand experience with a Mustang on this subject.
Old Feb 22, 2007 | 01:54 PM
yellowgtstang18
my diablo tuner i raised the shift firmness all they way up and it made a huge difference..
Old Feb 22, 2007 | 01:56 PM
Diesle's Avatar
Diesle
would both shift kit and tuner be a waste of money ???
Old Feb 22, 2007 | 01:57 PM
yellowgtstang18
no they both would help. So would a stall convertor.
Old Feb 22, 2007 | 02:02 PM
GreyStang's Avatar
GreyStang
ORIGINAL: Diesle
The tuner does more things than just alter shift points, but if that is all you want to do with it then yea it would be a waste to get both
Stall converters help you out if your a heavy drag racer, but won't do much else. And it will probably reduce your fuel economy.
Old Feb 22, 2007 | 05:57 PM
TorchRed04GT's Avatar
TorchRed04GT
Don't adjust shift firmness with a tuner. All it does is increase the line pressure. Go with a shift kit instead.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Explosive
Oct 2, 2015 07:45 AM
