thermostat question
Old Feb 22, 2007 | 07:48 PM
xcodegt's Avatar
xcodegt
Default thermostat question
would i hve to change the tune on my 02 GT if i were to switch to a 160 degree thermostat? Would I gain anything?
Old Feb 22, 2007 | 07:50 PM
sitnlopro99gt's Avatar
sitnlopro99gt
Default RE: thermostat question
no keep the thermo you got it will run rich and like ****...a car is meant to run hot to an extent.....don't mess with it
Old Feb 22, 2007 | 07:58 PM
ponysnake99's Avatar
ponysnake99
if you want a thermostat get a 180*, like sitnlopro said...you need a certain amount of heat to make good hp, and a 180 keeps the engine a little cooler but still in a good heat range to make optimal hp...and the only reason i see you needing a tuner for it is if they allow you to adjust the engine temp range
Old Feb 22, 2007 | 08:36 PM
oxfordgt's Avatar
oxfordgt
160* Tstat will keep your car in warmup mode and cause it to run rich. It can lead to a short engine life.
Old Feb 22, 2007 | 10:24 PM
Jakes's Avatar
Jakes
As others have said, a 160* stat will give the ECM some fits.Ocassionaly it will think the car is still warming up and keep it inopen loop operation (fuel, spark, etc, from internal tables) instead of closed loop (letting the ECM use the O2 sensors feed back to set fuel, spark,etc.). Runs rich.If you must change the stat use a 180*.
If you do change the stat (160* or 180*)you should go in to the ECM and change the "fan on and off" settings to match which ever stat you use. Hp gains are negligable but the cooler engine will love you for it.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
