blinker fluid
RE: blinker fluid
There is an electronic flasher module in the car that runs the turn signals and hazard lamps. This module has a function that warns the driver when a lamp burns out by flashing at about twice the normal flash rate
http://www.mustanghowto.com/exterior...Sequential.htm
^ thats a quote from that site, i didn't know about itbefore handtil i read it so i hope it helps
RE: blinker fluid
Check if the cornerlights come on when your lights are on. It doesn't have to be the "blinking" light. These bulbs have two fillaments and if either one goes out it will blink fast. If not, then the flasher is probably going out. I replaced mine about 2 weeks ago, but my blinkers stopped blinking completely.
RE: blinker fluid
Umm. My parking lights work normally, headlights work normally and my brake lights work normally. The only thing wrong i notice is my left turn signal, and the front and back turn signal and the gauge cluster indicators are all in sync
