vibrating at 60mph +
Old Feb 23, 2007 | 11:19 PM
svt99redcobra's Avatar
svt99redcobra
Default RE: vibrating at 60mph +
ORIGINAL: cliffyk
A problem with warped rotors is quite noticable under moderately hard braking--however they could be out of balance if they are old or some el-cheapo brand. I took a pair of inexpensive front rotors off a friend's ;02 GT and we found one weighed almost 3 pounds more then the other.[/align][/align]I had a pronounced vibration on my '03 GT at 45-50 that was absolutely tire balance related, even after having the balancing done 3 times. I identified the offending wheel (left front) and had the tire dismounted. We then spun up the wheel to make it wasn't bad,thenremounted the tire rotated 90° from the original position and rebalanced--problem gone...[/align][/align]
determined huh.....
atleast you found the problem.
Old Feb 23, 2007 | 11:33 PM
rmtaylor78's Avatar
rmtaylor78
thanks for the input. i guess i'll start looking for some nice new rotors. i'll take it back to the dealer on monday and have them check it out. i haven't had problems braking, but it sounds logical to me, especially if one weighs significantly more than the other. i was worried that the drive shaft needed to be balanced or replaced.
Old Feb 24, 2007 | 03:02 AM
V1PWRED's Avatar
V1PWRED
Had the same problem, rear rotors were warped
Old Feb 24, 2007 | 03:08 AM
GTMustang6921's Avatar
GTMustang6921
prob ur rotors...i invested in ford racing cross drilled and slotted rotors with ceramic red stuff pads off summit, 256 was my total...brakes incredibly well
Old Feb 24, 2007 | 04:01 AM
St4ng07's Avatar
St4ng07
Warped rotors. My car did the same thing when I first got it. Changed rotors and pads it was A ok!
Old Feb 24, 2007 | 02:51 PM
Andrew00GT's Avatar
Andrew00GT
i wouldnt say rotors unless it is vibrating when your braking... other then that NOT your rotors!... wheel alignment, driveshaft out of balance. i had a vibration got my tires re balanced and it was fine and now i have a vibration in the rear end at 80mph. cant figure this one out
Old Feb 24, 2007 | 02:55 PM
Quicktime_GT's Avatar
Quicktime_GT
I have a vibration at about 90mph +. I didn't notice it until I had 4.10s installed, maybe its the increased driveshaft rotations at that speed.. who knows..
Old Feb 24, 2007 | 03:13 PM
BBond007's Avatar
BBond007
ORIGINAL: sprostang
ORIGINAL: rmtaylor78
Can anyone help me out and let me know why my car rattles your teeth at speeds oover 60mph? I've already done the obvious and had the tires balanced. This is a constant problem, doesn't matter what the weather is, etc. I have a 5 spd '04 GT.
Check your u-joints.
Yeah,
my u-joint was shot and it vibrated like mad when you let off the gas at high speeds.
i ended up getting an aluminum drive shaft and my car has never ridden smoother.
Old Feb 24, 2007 | 03:18 PM
BBond007's Avatar
BBond007
ORIGINAL: Quicktime_GT
I read a few posts about people putting in gears and needing to get the drive shaft balanced to eliminate that vibration.
Old Feb 24, 2007 | 04:21 PM
98MustangSTL's Avatar
98MustangSTL
U-joints. Jack the car up and check it out. Pull on your driveshaft. It should be in there tight. If there is some play, you'll probably need u-joints. If one is bad, do both.
