Cleaning MAF
its easy to get to its the sensor attached to your Cold air intake system. Here check this it tells you how to clean the maf wire and has pictures to show you where everything is.
http://www.muscularmustangs.com/maf.php
It should be in the same location on your car and look the same.. I cleaned mine and took the screen out that sat in the cold air intake. Might help with idle problems.
jwog666
Dec 27, 2021 08:09 PM
