MAF screen
ORIGINAL: oxfordgt
You guys need to learn to listen to the guys that know what they are talking about. That screen evens out the flow of the air. If you have a fenderwell intake you really need it because those things are bad on the airflow (except JLT). If you have a staight shot then you could live without it but I would leave it in. It is there for a reason and not to stop stuff that gets past the filter, thats the dumbest **** I ever heard. If your car seems to run fine without it I'm glad for you but I doubt you hooked up a wideband to see what it is doing tou your A/F ratio. Stop giving out bad info you know nothing about. If the shoe fits wear it.
ORIGINAL: 2k1gt
Hes right. There were plenty of posts about this about a year or two ago. The screen does make a difference. Like I stated before, mine ran bad without it and great with it.
ORIGINAL: oxfordgt
ORIGINAL: str8wick3d
LOL I call bs.This screen is basically just a 2nd filter. More restriction. Its their to work with your stock intake for a reason.. Crappy filter? Installing a Cold air intake with a good filter eliminates the need for it.. If your getting rough idle this would be the last thing I blammed it on, If its rough idle Its probably due to improper installation, most likely the line connected to your IAC. Also The simpliest things can be over looked. U most likely unplugged your MAF sensor during the Cold air intake Install... or screen removal. Make sure u check before you blame a little peice of metal that *restricts* airflow.
+1
ORIGINAL: GTMustang6921
My buddy whop graduated UTI specialized ford. He said to leave it in that it can f*ck with your timeing...just a little somehting to pass along. because i was thinking about doing it and now decided not to
+1
jwog666
Dec 27, 2021 08:09 PM
yourmom6990
Sep 14, 2015 10:52 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
