Which mustangs had Romeo/Winsor engines?
#21
RE: Which mustangs had Romeo/Winsor engines?
ORIGINAL: lizzyfan
So the block was cast in Windsor but the heads are Romeo???
ORIGINAL: korn253
All mustangs up to 04 were assembled in Dearborn, Michigan. Windsor and Romeo are casting plants, all they do there is make engines.
ORIGINAL: lizzyfan
I'll ask again, the X in my vin number (8th digit) supposedly tells you were the vehicle was made, is this true?
ORIGINAL: droptoppony
96-98 = Romeo
99-00 = Windsor
01-04 = Romeo
all are interchangeable with minor changes
96-98 = Romeo
99-00 = Windsor
01-04 = Romeo
just in 99-00, every other engine had 100% romeo parts.
#22
X means winsor. It is also stamped W in the valley of the block under the intake manifold. Check your vins 8th character. You can also tell by the number of bolts on your valve covers.
#25
ORIGINAL: DTK
Mine has the X but it isn't a Windsor. It is a Romeo and has 11 bolts in the cover.
#26
Yeah it is sometimes confusing. Mine is a 2004.
I have seen sites selling heads and such saying to check your VIN and if it has the X order the Windsor stuff. That would be a pain in the *** to do that and get the wrong heads and only find out when the engine is stripped down.
#27
Here is a thread I came across on the Modular Depot talking about the two engines.
http://forums.modulardepot.com/4-6l-...r-engines.html
#30
here is my vin decoded
World Manufacturer Identifier -
1st, 2nd, 3rd Positions
VIN Code:1FA
Assembly Country:USA
Make:Ford
Body Style:Coupe
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code:F
Restraint:BELT, ACTIVE, AIRBAG
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code:P42
Vehicle Line:Mustang Series:GT
Vehicle Type:Car/Minivan
Engine Type - 8th Position
VIN Code:X
Engine:4.6 L
Cylinders:8
Fuel:Gasoline
Horsepower:225 HORSEPOWER
Model Year - 10th Position
VIN Code:3
Model Year:2003
Assembly Plant - 11th Position
VIN Code:F
Assembly PlantEARBORN: DEARBORN, MI
Production Sequence Number - 12th - 17th
VIN Code:417312
Prod Sequence Number417312
VIN Code:1FA
Make:Ford
Body Style:Coupe
VIN Code:F
VIN Code:P42
VIN Code:X
Engine:4.6 L
Cylinders:8
Fuel:Gasoline
VIN Code:3
Model Year:2003
VIN Code:F
VIN Code:417312
