how much hp again!
Old Feb 28, 2007 | 09:16 PM
Fuel's Avatar
Fuel
Default how much hp again!
what kind of #s do u guys think that a nonpi headed mustang with pi cams and full boltons would make if it was running a roots blower at 6, 9 and 12 psi
also #s if i went with pi heads and blower cams
help me out, btw my DZ 2" lowering springs just got here today
Old Feb 28, 2007 | 09:53 PM
Fuel's Avatar
Fuel
Default RE: how much hp again!
btw muy goal is really only 400 rwhp or just above
Old Feb 28, 2007 | 09:56 PM
runninmike's Avatar
runninmike
I would suggest getting the mods done, get a dyno pull, then figure a 50% increase in gross power after the blower is added.
Nobody can give a realistic guesstimate of how much random power it would create with "full bolt ons".
Old Feb 28, 2007 | 10:10 PM
Fuel's Avatar
Fuel
then how about with just the bolt ons that are in my sig, u guys can gibe me a close estimate can't u, just looking to know if i can get close to my goal
Old Feb 28, 2007 | 10:31 PM
97stanger's Avatar
97stanger
buddy of mine has full bolt ons, mild blower cams, pi intake, and a procharger running 13lbs through non pi heads, untouched making 385rwhp just to give you an estimate...keep in mind his car isn't even intercooled
Old Mar 1, 2007 | 12:51 AM
Fuel's Avatar
Fuel
bump for the later crowd
Old Mar 1, 2007 | 12:55 AM
yourmom6990's Avatar
yourmom6990
yeah, as long as you get the pi cams, and intake w/ full bolt on's and the blower w/ a nice tune i could easily see it being close to 400. the nonpi heads arnt that bad. they only lose about 10hp. the intake and cams are wayyyy more restrictive. good luck!
Old Mar 1, 2007 | 12:56 AM
red2k1gt's Avatar
red2k1gt
Well theres a good chance it would have a significantly lower lifespan after you do a PI swap and do 12psi through it. Most people with PI swapped cars run very conservative tunes due to the high compression and avoid blowing their motors. Remember the engine is only strong enough to handle 425hp on a a regular PI car. You could probably get ~400hp pretty easily but how long would it last?
Old Mar 1, 2007 | 12:59 AM
Fuel's Avatar
Fuel
okay, btw the pi intake wouldn't matter anymore since it is a roots blower so it comes with its own intake
also i am not doing the heads so the compression ratio wouldn't be too high and i am going to go forged so don't worry about that
just want to know some #s
this is the blower http://www.livernoismotorsports.com/product.phtml?p=744
Old Mar 1, 2007 | 01:04 AM
droptoppony's Avatar
droptoppony
about 320 rwhp on 6psi with pi cams...you will probably need head work, blower cams and 8-9 psi to approach 375rwhp with that eaton m-90 you were looking at.
