front crank seal
Old Mar 1, 2007 | 06:51 PM
CAROLINAHAND74's Avatar
CAROLINAHAND74
Default front crank seal
anyone ever have trouble with a front crankseal on a forged steel crank. just switched mine and ive went through 2 seals cause i thought maybe i got a bad one . but still no luck.
Old Mar 1, 2007 | 06:56 PM
oxfordgt's Avatar
oxfordgt
Default RE: front crank seal
Did you oil the seal first?
Old Mar 1, 2007 | 07:00 PM
CAROLINAHAND74
yep i think i gotta take that center bolt out and silicon it and try that. someone told me it will force out the forged steel cranks
Old Mar 1, 2007 | 07:32 PM
bryanec's Avatar
bryanec
Did you put silicone in the keyway?
[align=left] [/align]
Old Mar 2, 2007 | 04:34 AM
FDNYBullitt's Avatar
FDNYBullitt
If you didn't silicone the key then you will always have a leak and it won't be the seal. Its the same on either crank, good luck.
Old Mar 2, 2007 | 11:28 AM
Pitt's Avatar
Pitt
After I installed my Steeda pullies Ive been getting an oil leak inside my damper. I didnt silicone the keyway, so I guess thats why. And also explains why there was silicone on the Center bolt when I took it out. Thanks for the info FDNY...
Old Mar 2, 2007 | 11:43 AM
97targa's Avatar
97targa
your seal is more than likely still good especially if it has oil flowing past it to lubricate it..lol Just clean as much oil as possible because the silicone will not stick to a surface that's contaminated wil oil!!!
Old Mar 2, 2007 | 03:46 PM
CAROLINAHAND74
i dont think he siliconed the keyway. damn that sux thankx yall
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Lethaldosage423
Oct 19, 2015 12:12 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Demodulates
Sep 18, 2015 11:14 AM
Wombatnation
Sep 13, 2015 09:16 PM
