Something wrong or bad memory?
I just finished adding Eibach's and KYB's to the rear along with FR5's and 315's. With the Automatic in park and the rear on jack stands both wheels turned. It's been a while since I worked on a posi ar but is this normal or is it posi going bad? I thought I remembered I should be able to turn the lug nuts and tighten them with the raar off the ground or is that with one wheel off the ground and one on? Thanks for something I should know! Mark
RE: Something wrong or bad memory?
Park. Pinion doesn't turn but with enough pressure on a lug nut as I tightened it the oposite wheel turned in the opposite direction. I thought I remembered doing this with another car and it was possible to tighten one wheel completely with the wheels off the ground?
KingRando
10-02-2015 08:06 AM
