How Hot Does Your Mustang Run?
Old 03-02-2007, 07:08 AM
SoulBurn18
SoulBurn18's Avatar
Default How Hot Does Your Mustang Run?
What temperature does your car run when you've been driving it for awhile?
SoulBurn18 is offline
Old 03-02-2007, 07:33 AM
04mineralgreyGT
04mineralgreyGT's Avatar
Default RE: How Hot Does Your Mustang Run?
I don't know the exact temperature but the needle on the factory gauge points strait up when the cars been run hard for an extended period of time. If ran normally the needle will be almost pointing strait up with a small lean back toward cool.
04mineralgreyGT is offline
Old 03-02-2007, 07:49 AM
SoulBurn18
SoulBurn18's Avatar
That's where mine is too. Does it help the engine any if it runs cooler? A co-worker said he put a 160 degree thermostat on his car so it stays below 160.
Old 03-02-2007, 08:01 AM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: SoulBurn18
If you want to run a cooler thermostat, go with a 180 which is what I'm running. 160 is just too cool and you may not get engine temps up to operating levels
lizzyfan is offline
Old 03-02-2007, 08:49 AM
SoulBurn18
SoulBurn18's Avatar
ORIGINAL: lizzyfan
So 180 is a good temperature for the car to be running at? It looks like it helps reduce wear and tear on the engine, improve performance and gas mileage. Is this true?
Old 03-02-2007, 09:02 AM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: lizzyfan
Yes, a nice medium
lizzyfan is offline
Old 03-02-2007, 10:21 AM
nanaki
Retired MF Moderator
nanaki's Avatar
haha. the gauges on the stang stock are practically painted on. there was a cobra at the shop that had the temp reading to be fine, but that thing was burnin the hell up. gogo ford!
nanaki is offline
Old 03-02-2007, 11:12 AM
SoulBurn18
SoulBurn18's Avatar
ORIGINAL: nanaki
That's reassuring, thanks.
Old 03-02-2007, 12:18 PM
uberstang1
Chupacabra
uberstang1's Avatar
a 180 will help, u can also pour a bottle of that watter wetter stuff in it too, im not sure if it acutally makes a differennce or not though
uberstang1 is offline
Old 03-02-2007, 12:30 PM
DesertMach
DesertMach's Avatar
ORIGINAL: 04mineralgreyGT
Ditto
DesertMach is offline
Quick Reply: How Hot Does Your Mustang Run?
