how much boost?
how much boost?
Ok i bought the novi 1000 and it was supposed to berunnin 6-8 lbs of boost. well i only hit 6.4 psi and i want more like 10 - 12 but i dont know what pulley to get, i dont know if i have a 8lb pulley now or what? What should i do?
RE: how much boost?
ORIGINAL: sstang
I would do a 10-12 psi pulley or get a power pipe.
RE: how much boost?
ok but what i'm sayin is do i have a 6 lb pulley or 8 and what size pulley will i need to go to in order to get 10 or 12 psi? what are the sizes of pulleys and their boost ratings? will a stock motor hold 12 psi? I think Nanaki has 12 but is that safe?
RE: how much boost?
hey man. I am purchasing a 02 gt with a 04 cobra block SOhc heads and a procharger setup with all the supporting mods. with some serious head work what kind of power u think i can make. I have a excellent tuner that i am friends with. I saw u had a similar setup so just wanted to know
DREW
DREW
RE: how much boost?
ORIGINAL: 97targa
A power pipe will not net you any more boost??? That's just a smooth inlet pipe. They call them power pipes! You need to measure the diameter across your pulley. It is probably close to 3". I'm not sure what a 10-12lb pulley but you can get them on ebay for around $20-80 plus shipping. They run $75-150 in the stores depending on the size. Maybe a 10-12lb is around 2.6"???
ORIGINAL: sstang
