h-pipe install failed
man what a b!tch it is to get the header bolts off of the stock h-pipe, i have o/r mac h-pipe for its place of stock. they were jus way to damn hard and i though i had more room to work with untill i got under there. any way that you could think of that might be a lil easier, and how much did you guys that payed to have someone put it in for you cost. thanx guys
RE: h-pipe install failed
Hit the bolts with some PB Blaster, and let it penetrate for a few minutes. Also, use the extentions and what not to get to the bolt, and then use a breaker bar or something to lengthen the handle of the socket wrench so that you can get more torque on the bolt. That should do it.
ORIGINAL: bullittracr
haha im use to using wd40 all the time i work on garage doors and thats waht i use. anyway what is PB
your new best friend...that stuff melts rust away. i got mine at a local auto parts store.
