suspension question
suspension question
Is this a good suspension kit to buy.?? http://www.uprproducts.com/shopping/shopexd.asp?id=141
RE: suspension question
Yeah, but for the street it's overkill and a downgrade. With that style "anti-roll" bar you will gain traction and improve your ft times, but you will not gain handling on the street, actually you will lose out! Also unless your putting slicks on and running both street and track tires then the upper adjustables are pointless and a waste of money. If you want improved performance go with the Eibach sway bar kit from StangSuspension for $299 includes front and rear add-on sway bars and they have steeda upper/lower kits too. You get a 5% discount if you enter the coupon code when you buy! They shipped my order out same day and have multiple shipping options! They stock most parts too!
ORIGINAL: 97targa
ORIGINAL: yellowgtstang18
ok thanx, also what the best upper and lower control arms to get??
Ohh you also NEED upgraded struts shocks...That will make tremendous diff along with the control arms. You can hit corners harder without the initialsquat of the suspension. Alsoyour slolomwill drastically improve
the stock setup is designed out of rubber to stretch and allow the uca's to move freely through its drop range, with aftermarket uca's they are either boxxed or urethane, these do little in giving slack to the uca's/axles or torque boxes.. so eventually something will give on one of the corners you turn. That is why when there are alot of people buying torque box reinforcements.
The snap oversteer occurs when you go into any given corner, and the combination of how hard your going into it and the grip of your tires, it will bind up, and once it does, your rear end will swing around and come out from underneath.
