Clutch question
Old Mar 9, 2007 | 02:56 AM
FirstStangGT02's Avatar
FirstStangGT02
Default Clutch question
What do you guys think about this clutch? SPEC Stage 1 Clutch (Mid 01-04 Mustang GT, 99-04 Cobra, and 03-04 Mach 1) Im looking for a clutch that has about half the throw my stock 02 gt clutch has. Anyone have any ideas? Whats a good clutch? Only going to push 350 wheel hp.
Old Mar 9, 2007 | 05:03 AM
2000GT4.6's Avatar
2000GT4.6
Default RE: Clutch question
The spec stage 1 should be enough to handle 350 WHP. Its going to be a little stiffer than stock but not much.
So much as the clutch travel, you will need to get a clutch quadrant and firewall adjuster to adjust where it engages/disengages, but the overall travel will be about the same.
If you want a little more insurance setup up to a stage 2. The clutch is still fairly easy to push in but has more grip than the stage 1.
Old Mar 9, 2007 | 05:08 AM
NORMAN99's Avatar
NORMAN99
I've got a dual friction clutch installed my 99 Stang by Center Force. The performance is just awesome.
Old Mar 9, 2007 | 08:50 AM
nanaki's Avatar
nanaki
Retired MF Moderator
if you do the stage 2, may as well go up one more to the stage 3 for 20 bucks more.
i don't know if they make the plus for stage 1 & 2, but those are apparently much better for the street. i didn't find out about the stage 3+ til after i had mine installed and ready to go. [:@] the stage 3 isn't bad though, it's not much stiffer than stock.
Old Mar 9, 2007 | 09:56 AM
FirstStangGT02
thanks guys, im thinking ill probably go with stage 2, where is the cheapest place to get the stage 2 clutch? Also willi need a new fly wheel?
Old Mar 9, 2007 | 11:45 AM
dgantt's Avatar
dgantt
American muscle has them at a good price, if you say your a member of this form you get an extra 5% off. I got mine for like 280 buck to my door.
Old Mar 9, 2007 | 02:40 PM
stang22jh's Avatar
stang22jh
if you are going to get the clutch replaced and you have the extra money, i would recommend upgrading your flywheel. you don't need to replace, but you will enjoy the benefits of the increased torque.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
