cobra short block
cobra short block
[/size]Image[/size]
Description
Part Number
Price
MMR 4.6 Street Mod 600 (up to 600HP)
(The perfect replacement for your forced induction or NOS GT)
*Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
*New Ford Racing Cast Iron 6 Bolt Crankshaft rated up to 600HP
*New 4340 5.933 MMR (Modular Mustang Racing H-beam Rods, these rods are
shotpeened, magnafluxed and weight matched w/ ARP rod bolts
*New Forged Manley pistons 3.552 Bore size
*Speed Pro file fit rings (precision file fit to your application,
nitrous, blower, turbo or N/A)
*Speed Pro/Federal Mogul Tri-metal Rod and Main bearings
*Complete Pro Assembly and Balancing for the smoothest, highest revving
shortblock available.
Shortblock Options:
Coated Pistons (ceramic dome/teflon skirt) $399.99
Brand New Current production Aluminum Block +$699.99 for NA or $729 S/C Blocks
Upgrade to forged crankshaft +249.99
ARP Mainstuds (recommended for 600+HP) +169.99
MMR Street/Racing Oil Pump (highly recommended) + $199.99
ARP Headstuds and MMR/Felpro Extreme Duty Headgaskets + $369.99
MMR windage tray and hardware kit (+15HP) + 129.99
*Due to the custom nature of MMR shortblocks ALL customers paying with a credit card
will be billed when the order is placed (prior to engine assembly and shipping),
All MMR shortblocks are non-refundable regardless if the item has shipped or not.
2,229$
Ok this site says that this is a good uprgrade for a gt but then it says cobra block. i will need new heads and stuff for this correct?
RE: cobra short block
well maybe, but this way i get it all balanced and everything and i dont have to screw with the crank, cuz i intend to do all the work i can myself. How much are Forged rotating assemblies by the way? i always find expensiveones. like 2 grand.
So 2 questions. . .
Can i just swap this for my motor?
Where can i find a good rotating assembly to forge it myself for cheaper than this?
So 2 questions. . .
hey sonicblue02 i see you live in N. Ft. Myers. i graduated from there in 05 and live in the cape. i am looking at doing the exact same thing from the exact same place(MMR). MMR also sells forged rotating assemballies. just look through the site. i am gonna get some Patriot Performance Stage II heads with their billet cams (similar to Comp Cams Stage II cams). Alaos if you get a big cam get the notched pistons MMR sells for $250. thats what im doing soon
