caster camber plates
whats the deal, i just unbolt the strut and put them in place of the plate that is already there? do i need to drill? whats the deal are they a bitch to put in or no
RE: caster camber plates
It Comes with Directions. if you get the 4bolt, you have to drill a Hole for the 4th Bolt, its not Hard. THe First one for me was Time consuming, then the Second i did went Quick, Just Follow the Instructions with it.
you have to drill out rivets and use impactgun to zip the strut nut off then there is 3 nuts underneath the wheelwell you got to take off. Mount up like you took apart except with the new stuff with correct bushings etc you can do it all with a floor jack and basic tools similar to a spring install....you not replacing struts or shocks?
