I maxed out at 110!! WTF
RE: I maxed out at 110!! WTF
+1 I had somewhat the same stuttering problem. Changed the coil packs and seems to be all better.
ORIGINAL: dubarado
check the coil packs, wires, plugs... if anything replace them... if that doesn't fix it, then take it to a tranny shop.
I get your drift on the wheel size... but being he said it made a loud clunk noise and didnt shift into the higher gear (OD?), and it now shudders, wheel size is probably a bit off at this point! I still say it is the Torque Converter or other related tranny problem... id also be interested to know what the tranny fluid level is like...
I used to have an 02 Camaro and ran into the same problem. The car used to shutter when I would accelerate. The harder I accelerated and the higher the RPMS went, the more it shuttered. It ended up being one of my coil packs. I would check them first. Fortunately, they are cheap to replace and easy!
-Vortexx
-Vortexx
ORIGINAL: Reed44
It sounds like your car detonated. I had a vortech on my car but my motor blew up from the guy at the dyno putting 16 degrees of timing in it. Before it blew though, it wouldnt go past 130mph, then 110mph, then 90mph. At that point my car had a miss and cyclinder #8 was dead. Four of my spark plugs were gone. Check yours before you get on it again.
