Aluminum block build question...
A buddy might be selling me the 4.6 out of his 99 GT when he swaps in a 5.4 (read: IF) and I'd like to replace the block with an aluminum one. My options will likely be either a Teksid block, or an explorer block. Anyone know if I'll run into trouble mounting accessories or finding a timing cover that fits with the PI heads on a 99 4.6 Windsor??
ORIGINAL: Rook6
I guess I'masking the tough questions these days lol
ORIGINAL: 97targa
No just another question that has been posted a thousand times! There's no reason to change out the block unless you have weight issues! If you do change the block you'll nee a complete rebuild of the lower half! The cast block can hold plenty of power! Save your money unless like I said if you planned on doing a complete rebuild. Also the mounting holes are the same!
For the curious...Teksid aluminumblocks, italian made and capable of some 900+ Hp are pretty much any 96-98 aluminum Ford block, and some left over ones were put in a few 99s. The ones from late 99 on were Aluminum Windsor blocks, which though about 5 lbs lighter, are only said to hold up to 700hp before splitting in half. For most people, either will do, really.
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
